[winGRASS] TCLTK repeat message as list member
Glynn Clements glynn.clements at virgin.net
Sat Mar 1 15:35:30 EST 2003
Ian Allan wrote:
> My problem is that when I display a monitor, TCLTK freezes & i cannot
> select any further options from the tcltk grass menu.The only hint i
> have about what the problem might be is that instructions were to
> "ensure the official cygwin tcltk package was not installed" & then
> install the tcltk stuff from the grass site. I assumed the official
> tcltk was not installed because under the cygwin setup program I could
> not see tcltk. Did i look in the right spot? I unpacked the xtcltk* file
> as instructed anyhow.  Any ideas?
If tcltkgrass appears within the X server's window, then it's using
the correct (Unix/X11) version of Tcl/Tk.
Glynn Clements <glynn.clements at virgin.net>
More information about the grass-windows mailing list
