[winGRASS] cygwin/wingrass install problems
Kathy Southerly kathy at portcitywebdesign.com
Sun Mar 9 11:16:01 EST 2003
I am trying to install grass 5.0 using a win2k machine with
cygwin.  Attempt one was using the compiled binary.  When running the
install script it returns no gunzip found.  gunzip is there and
functional.  Testing on another machine, it appears to have installed fine
using the same downloaded install files on WinXPpro.  As an alternative,
attempt two, I downloaded the source code for 5.0.1 to compile.  When
running the configure it returns the error that the gcc compiler is not
functioning.  Again gcc is there and functional.  Any ideas or
suggestions?  It seems to be purely a cygwin problem.  Is the solution to
simply setup a linux box again to run grass?
Thanks
More information about the grass-windows mailing list
