[winGRASS] GDAL and cygwin - crossposting
John Huddleston jhudd at lamar.colostate.edu
Fri May 16 11:17:07 EDT 2003
To WinGrass list,
I've built gdal before but this was the first time from their cvs repository.
First, of more informational value is the versions of  Frank's components
which can be listed using cygcheck command.  i.e.
cygcheck  -V
cygcheck -s | grep tiff
cygcheck -s | grep jpeg
My version is 1.32 so ask Frank for his output.
Second, I configured gdal but there were two problems
edit two GNUmakefiles in
gdal/frmts/gtiff/GNUmakefile
gdal/frmts/gtiff/libgeotiff/GNUmakefile
to add -I/usr/include
My gcc version is 3.2-3.
John Huddleston
-----Original Message-----
From: wingrass-admin at grass.itc.it [mailto:wingrass-admin at grass.itc.it]On
Behalf Of Markus Neteler
Sent: Thursday, May 15, 2003 4:39 AM
To: wingrass at grass.itc.it
Subject: [winGRASS] GDAL and cygwin - crossposting
For those being interested in GDAL on Cygwin (r.in.gdal),
may read following posting from the GDAL mailing list.
Markus
The thread:
 http://remotesensing.org/pipermail/gdal-dev/2003-May/000621.html
 Re: [Gdal-dev] python support under cygwin
On Wed, May 14, 2003 at 03:50:28PM -0400, Frank Warmerdam wrote:
> I have spent a couple of hours fiddling with the GDAL built on Cygwin.  I
> found I had to upgrade to the latest Cygwin (1.3.22) to get good functioning
> out of the DLL building support in Cygwin.  I also had to hack around at
> the configure logic a bit for python support.  But now I am able to configure
> GDAL out of the box on Cygwin and get a Python shared library (libgdal.1.1.dll)
> and python support.
> I would encourage you to try rebuilding tomorrow from the nightly snapshot,
> or pull the current version out of CVS.
> Known and suspected issues:
>   o I was using the internal versions of libtiff, libpng, libjpeg and so
>     forth because I avoided installing the cygwin versions at all.  I don't
>     know if the cygwin versions will work or not, but I see the cygwin folks
>     have updated to libtiff 3.6.0 already so it might.
>   o I tried building and installing PROJ from CVS.  It works, but PROJ didn't
>     produce shared libraries, and so the aspects of GDAL that utilize PROJ
>     aren't going to work ... well, perhaps static PROJ linking could be
>     utilized but that isn't trivial out of the box.
> I have things setup so I can use a clean Cygwin environment on my NT partition
> now, so perhaps I will do a better job at maintaining Cygwin build support in
> the future.
> I would also like to mention that I got most of the required changes from
> Norman Vine's cygMakefile in gdal/pymod.  If I listened a little closer to
> what Norman keeps telling me I am sure we would have had much better cygwin
> support for some time.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
winGRASS mailing list
winGRASS at grass.itc.it
http://grass.itc.it/mailman/listinfo/wingrass
More information about the grass-windows mailing list
