[winGRASS] d.mon socket problem
Glynn Clements glynn.clements at virgin.net
Wed May 21 20:12:22 EDT 2003
Mike Thomas wrote:
> Actually, I built both the X and generic Cygwin binary downloads with
> __W98__ defined to ensure that both versions would work on Windows 98 (upon
> which platform fork() was indeed broken a year or two ago).
OK; I had forgotten about that. FWIW, fork() is *still* broken on
Win98.
However, if I use the __W98__ version of mon.start, I don't have any
problems (other than the warning message on the first attempt, which
is to be expected). This is with the CVS HEAD, Win98, Cygwin updated
yesterday (everything except gcc, which is still 2.95.3-5).
To be honest, I consider it a minor miracle that so much of GRASS
actually works at all under Cygwin. In the longer term (i.e. 5.1), we
really need to stop relying upon Cygwin (which will *always* be flaky)
and start making GRASS portable.
Glynn Clements <glynn.clements at virgin.net>
More information about the grass-windows mailing list
