[winGRASS] Re: [GRASSLIST:3293] default start files
Glynn Clements glynn.clements at virgin.net
Wed Apr 28 11:55:01 EDT 2004
Mike Francis wrote:
> Could someone tell me where on a Cygwin set-up the default location and
> name is for grass5 startup file/s. I need to access it/them from a batch
> file.
What do you mean by "startup file/s"? The session file (which contains
the current database, location and mapset) is $HOME/.grassrc5. The
script which is used to start a GRASS session is usually
/usr/local/bin/grass5 (or grass53/grass57 for the development
versions).
Glynn Clements <glynn.clements at virgin.net>
More information about the grass-windows mailing list
