[winGRASS] the " libgrass_gis.dll was not found !" problem
Huidae Cho grass4u at gmail.com
Sat Dec 11 21:13:25 EST 2004
OK, ps.map seems to be able to find all libraries.
But libgrass_gis.dll and libgrass_I.dll shouldn't be there. You know,
linked libraries cannot be loaded at run-time because M$-Windows doesn't
support UNIX link. Instead, these linked libraries are used at
compile-time. I don't know why your binary (should be the same as mine)
is linked against libgrass_gis.dll and libgrass_I.dll. Did you compile
it yourself?
Try the following:
1. Delete non 5.7.cvs.dll files and relink them:
   cd /usr/local/grass5.7.cvs-i686-pc-cygwin-11_12_2004/lib
   for i in `/usr/bin/ls | grep -v 5.7.cvs | sed 's/\.dll$//'`
   do
      rm -f $i.dll
      ln -s $i.5.7.cvs.dll $i.dll
   done
2. cygcheck /usr/local/grass5.7.cvs-i686-pc-cygwin-11_12_2004/bin/ps.map
Now, ps.map shouldn't be able to find libgrass_gis.dll.  Right?
Huidae Cho
On Sun, Dec 12, 2004 at 03:40:26AM +0200, Koukoulas Sotiris wrote:
> >Please check your library dependency of whatever command you run:
> >cygcheck /usr/local/grass.../bin/ps.map
> >Then it should print libraries that it requires. Try this in and
> outside
> >grass.
> Done that and here are the results (all not found files exist! -see
> lib_list attached):
> 1. Outside grass on the cygwin prompt: -------------------------------
> $ cygcheck /usr/local/grass5.7.cvs-i686-pc-cygwin-11_12_2004/bin/ps.map
> P:/cygwin/usr/local/grass5.7.cvs-i686-pc-cygwin-11_12_2004/bin/ps.map
>   P:\cygwin\bin\cygwin1.dll
>     C:\WINDOWS\system32\ADVAPI32.DLL
>       C:\WINDOWS\system32\ntdll.dll
>       C:\WINDOWS\system32\KERNEL32.dll
>       C:\WINDOWS\system32\RPCRT4.dll
> Error: could not find libgrass_I.5.7.cvs.dll
> Error: could not find libgrass_gis.5.7.cvs.dll
> Error: could not find libgrass_symb.5.7.cvs.dll
> Error: could not find libgrass_gproj.5.7.cvs.dll
> Error: could not find libgrass_vect.5.7.cvs.dll
> 2. From grass5.7 prompt: -----------------------------------
> GRASS 5.7.cvs:~ > cygcheck /usr/local/grass5.7.cvs-i686-pc-cygwin
> P:\cygwin\usr\local\grass5.7.cvs-i686-pc-cygwin-11_12_2004\lib\libgrass_
> I.5.7.cvs.dll
> vask.5.7.cvs.dll
>       P:\cygwin\bin\cygncurses-8.dll
> gis.5.7.cvs.dll
>       P:\cygwin\bin\cygz.dll
> datetime.5.7.cvs.dll
> gmath.5.7.cvs.dll
> symb.5.7.cvs.dll
> gproj.5.7.cvs.dll
>     P:\cygwin\bin\cygproj-0.dll
>     P:\cygwin\usr\local\bin\cyggdal-1.dll
>       P:\cygwin\bin\cygjasper-1-701-1.dll
>         P:\cygwin\bin\cygjpeg-62.dll
>       P:\cygwin\bin\cygpng12.dll
>       P:\cygwin\bin\pq.dll
>         P:\cygwin\bin\cygcrypt-0.dll
>         P:\cygwin\bin\cygcrypto-0.9.7.dll
>         P:\cygwin\bin\cygssl-0.9.7.dll
>       P:\cygwin\bin\cygtiff4.dll
> gis.dll
> I.dll
> vect.5.7.cvs.dll
> dbmibase.5.7.cvs.dll
> dbmiclient.5.7.cvs.dll
> linkm.5.7.cvs.dll
> rtree.5.7.cvs.dll
> dgl.5.7.cvs.dll
> dig2.5.7.cvs.dll
> GRASS 5.7.cvs:~ >
More information about the grass-windows mailing list
