[winGRASS] v.in.mif
Richard Greenwood rich at greenwoodmap.com
Sat Jan 17 08:57:59 EST 2004
Patrick Giraudoux wrote:
> I am a beginner trying to import vector data from a MapInfo file, but
> the command v.in.mif is not recognised.
> GRASS:~>v.in.mif help
> bash: v.in.mif: command not found
> Even with the TCLTKGRASS 3.2 (2001) menu, I can get in "various
> format" only three items Ascii DLG, Ascii VECTOR or Binary VECTOR file
> and a limited number of possibilities (ASCII Grass vector file,
> ARC/INFO ungenerate file, ESRI shapefile, AUTOCAD DXF file, Various
> formats and Garmin GPS Waypoints/Routes/Tracks.
> I am working with GRASS 5.0.2
Forgot to mention earlier;if you do not have access to MapInfo, you
should look at ogr2ogr at:
    http://www.remotesensing.org/gdal/
Richard Greenwood
www.greenwoodmap.com
More information about the grass-windows mailing list
