[winGRASS] help on 5.7
Helmut Muenzing hmc at sflu.com
Thu Nov 25 02:41:35 EST 2004
Thanks.
I installed MOZILLA.
My TCLTKGRASS 4.0(April 2004)interface does not have a Configuration Menu.
Though under File there is a Configure Menu which only lets you resize Menu Size
and select Menu Fonts.
Is there a configuration file I can edit directly?
Regards
Helmut Muenzing
hmc at sflu.com
-----Original Message-----
From: wingrass-admin at grass.itc.it [mailto:wingrass-admin at grass.itc.it] On Behalf
Of Richard Greenwood
Sent: Thursday, 25 November, 2004 10:00
To: hmc at sflu.com
Cc: wingrass at grass.itc.it
Subject: Re: [winGRASS] r.mask & mozilla on 5.7
On Thu, 25 Nov 2004 09:40:09 +0800, Helmut Muenzing <hmc at sflu.com> wrote:
> Perhaps it is just my ignorance, but I cannot find command r.mask anymore in
> version 5.7. (I am using Huidae Cho's binaries of 03-Nov-04.)
See:
    http://article.gmane.org/gmane.comp.gis.grass.user/6292
> The help system requires mozilla or konqueror. Probably, this has to be
> installed under the CYGWIN environment. But CYGWIN does not provide the
> browsers. How to go about it?
See:
    http://article.gmane.org/gmane.comp.gis.grass.user/6333
This should work with Cygwin if Mozilla is installed on the computer.
Richard Greenwood
richard.greenwood at gmail.com
www.greenwoodmap.com
winGRASS mailing list
winGRASS at grass.itc.it
http://grass.itc.it/mailman/listinfo/wingrass
More information about the grass-windows mailing list
