[winGRASS] Re: problem starting grass
Martin Perra
mperra at petrelrob.com
Wed Oct 13 10:19:41 EDT 2004
I am using a new install of Cygwin, I installed everything EXCEPT tcl/tk
libraries. I downloaded the proper ones from the grass5.7 directory, and
installed using provided .sh file.
I ran which -a wish, and came up with one in /usr/local/bin. Date is
3/28/2002, size is 1209kb file is wish8.3.exe
I'll explain a little more background on the problem. At one point I had
everything working properly. I then installed vis5d+ and that worked, but
when I went back to grass, I got the error message i mentioned before.
After trying a few things, I ended up deleteating Cygwin completly, and
reinstalling, including grass (I have tried all versions 5, 5.3, 5.7) and
get the same problem. I have tried doing full reinstalls afew times,
including deleting all cygwin Windows registry entries with no luck.
I don't recall if when I installed vis5d I had to get cygwinb19 from
somwhere to make it work, It was awhile ago. I think I may have though,
because it was requesting it, and I would have put it in c:\cygwin\bin.
That may be what caused the problem, but like I said, I have since deleted
all traces of it.
I am wondering if it may be becuase of my home path? After install, it is
set to a network share, which is my windows home directory. Could this be
causing a problem? How might I fix it? I am fairly new to Unix-like
sytems.
I have just tried copying mysql.exe and the dll to /usr/local/bin but that
didn't help.
When installed cygwin, I got this message the first time I ran it.
Your group is currently \"mkgroup\". This indicates that
the /etc/group (and possibly /etc/passwd) files should be rebuilt.
See the man pages for mkpasswd and mkgroup then, for example, run
mkpasswd -l [-d] > /etc/passwd
mkgroup -l [-d] > /etc/group
Note that the -d switch is necessary for domain users.
I'm not sure aht it means though.
I hope that's enough information to work an answer out of!
Thanks,
Martin
-----Original Message-----
From: wingrass-admin at grass.itc.it [mailto:wingrass-admin at grass.itc.it]On
Behalf Of wingrass-request at grass.itc.it
Sent: Sunday, October 10, 2004 4:01 AM
To: wingrass at grass.itc.it
Subject: winGRASS digest, Vol 1 #220 - 6 msgs
Send winGRASS mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
http://grass.itc.it/mailman/listinfo/wingrass
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
When replying, please edit your Subject line so it is more specific
than "Re: Contents of winGRASS digest..."
Today's Topics:
1. pg.dll not found in W2K Svp4 (Bayer.Juergen (FORST))
2. Re: pg.dll not found in W2K Svp4 (=?ISO-8859-1?Q?=C1d=E1m_Csaba?=)
3. include winGRASS with Cygwin distribution? (Gerrit P. Haase)
4. Re: problem starting grass (Richard Greenwood)
5. Re: problem starting grass (Gerrit P. Haase)
6. Re: problem starting grass (Gerrit P. Haase)
--__--__--
Message: 1
From: "Bayer.Juergen (FORST)" <Juergen.Bayer at forst.bwl.de>
Date: Sat, 9 Oct 2004 16:57:30 +0200
Subject: [winGRASS] pg.dll not found in W2K Svp4
This message is in MIME format. Since your mail reader does not understand
this format, some or all of this message may not be legible.
------_=_NextPart_001_01C4AE10.4CD08420
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Have just installed grass57 and the latest cygwin release from bineary
installs.
Get it started but after displaying the first maps or when opening most
dialogs boxes, I get a PG.DLL is missing message from several tools =
(e.g.
ps.map). I think I had installed cygwin with almost all components.
=20
All on W2K, Svp4, German release
=20
Any idea what component is missing? If not: pg.dll should be located
anywhere in the winnt tree or in any other folder set within the PATH
variable.=20
=20
Thanks Juergen
=20
=20
=20
=20
=20
*********************************************************<?xml:namespace=
prefix =3D o ns =3D "urn:schemas-microsoft-com:office:office" />
J=FCrgen Bayer
Forstliche Versuchs- und Forschungsanstalt Baden-W=FCrttemberg/VfS
Abteilung Wald=F6kologie
Wonnhaldestr. 4
79110 Freiburg
<mailto:Juergen.Bayer at forst.bwl.de> Juergen.Bayer at forst.bwl.de
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2800.1141" name=3DGENERATOR></HEAD>
<BODY>
<DIV><FONT face=3DArial size=3D2><SPAN class=3D926315014-09102004>Have =
just installed=20
grass57 and the latest cygwin release from bineary =
installs.</SPAN></FONT></DIV>
<DIV><FONT face=3DArial size=3D2><SPAN class=3D926315014-09102004>Get =
it started but=20
after displaying the first maps or when opening most dialogs boxes, I =
get a=20
PG.DLL is missing message from several tools (e.g. ps.map). I think I =
had=20
installed cygwin with almost all components.</SPAN></FONT></DIV>
<DIV><FONT face=3DArial size=3D2><SPAN=20
class=3D926315014-09102004></SPAN></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2><SPAN class=3D926315014-09102004>All =
on W2K, Svp4,=20
German release</SPAN></FONT></DIV>
<DIV><FONT face=3DArial size=3D2><SPAN class=3D926315014-09102004>Any =
idea what=20
component is missing? If not: pg.dll should be located anywhere in the =
winnt=20
tree or in any other folder set within the PATH variable. =
<DIV><FONT face=3DArial size=3D2><SPAN =
class=3D926315014-09102004>Thanks=20
Juergen</SPAN></FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV class=3DSection1>
<P style=3D"MARGIN: 0cm 0cm 0pt"><SPAN=20
style=3D"FONT-SIZE: 7.5pt; COLOR: navy; FONT-FAMILY: =
Arial">*********************************************************</SPAN><=
SPAN=20
style=3D"FONT-SIZE: 10pt"><?xml:namespace prefix =3D o ns =3D=20
"urn:schemas-microsoft-com:office:office" /><o:p></o:p></SPAN></P>
style=3D"FONT-SIZE: 7.5pt; COLOR: navy; FONT-FAMILY: Arial">J=FCrgen=20
Bayer</SPAN><SPAN style=3D"FONT-SIZE: 10pt"><o:p></o:p></SPAN></P>
style=3D"FONT-SIZE: 7.5pt; COLOR: navy; FONT-FAMILY: Arial">Forstliche =
Versuchs-=20
und Forschungsanstalt Baden-W=FCrttemberg/VfS</SPAN><SPAN=20
style=3D"FONT-SIZE: 7.5pt; COLOR: navy; FONT-FAMILY: Arial">Abteilung=20
Wald=F6kologie</SPAN><SPAN style=3D"FONT-SIZE: =
Arial">Wonnhaldestr.=20
4</SPAN><SPAN style=3D"FONT-SIZE: 10pt"><o:p></o:p></SPAN></P>
style=3D"FONT-SIZE: 7.5pt; COLOR: navy; FONT-FAMILY: Arial">79110=20
Freiburg</SPAN><SPAN style=3D"FONT-SIZE: 10pt"><o:p></o:p></SPAN></P>
<P style=3D"MARGIN: 0cm 0cm 0pt"><SPAN style=3D"FONT-SIZE: 10pt"><A=20
href=3D"mailto:Juergen.Bayer at forst.bwl.de"><SPAN=20
Arial">Juergen.Bayer at forst.bwl.de</SPAN></A><o:p></o:p></SPAN></P>
SPAN=20
10pt"><o:p></o:p></SPAN></P></DIV></DIV></BODY></HTML>
------_=_NextPart_001_01C4AE10.4CD08420--
--__--__--
Message: 2
Date: Sat, 09 Oct 2004 17:50:03 +0200
From: =?ISO-8859-1?Q?=C1d=E1m_Csaba?= <csaba at adamiroda.hu>
Subject: Re: [winGRASS] pg.dll not found in W2K Svp4
Hi Juergen,
> ...I get a PG.DLL is missing message ...
I have no pure "pg.dll" in the Cygwin directory.
There are pg_blah-blah.dlls in the /bin/ dir, but
they belong to the PostgreSQL.
And there is a "pq.dll" in the /bin/ (PQ.DLL).
That's all.
Regards,
Csaba
--__--__--
Message: 3
Date: Sun, 10 Oct 2004 01:21:11 +0200
Organization: Esse keine toten Tiere
Subject: [winGRASS] include winGRASS with Cygwin distribution?
Hello,
whoever is maintaing the Cygwin port of winGRASS, isn't there interest
to include winGRASS as a package with the Cygwin net distribution, so
people could use setup.exe to install wniGRASS including dependencies?
We're also right now discussing at the Cygwin maintainer list about the
inclusion PostGIS as an addon to the POstgreSQL package, however I don't
now if that belongs here.
Gerrit
--__--__--
Message: 4
Date: Sat, 09 Oct 2004 18:31:24 -0600
To: "Gerrit P. Haase" <gp at familiehaase.de>
CC: mperra at petrelrob.com, wingrass at grass.itc.it
Subject: Re: [winGRASS] problem starting grass
Gerrit P. Haase wrote:
> Martin Perra wrote:
>> when I type "grass57" I get a popup titled "wish8.3.exe - unable to
>> locate
>> component" The message says "This application failed to start because
>> cygwinb19.dll was not found. Re-installing the application may fix this
>> problem"
>> Any ideas?
> Get a new TCL package, yours must be at least 5 years old.
> Gerrit
No, don't update Tcl/Tk, Grass requires a modified version of Tcl/Tk
found at:
http://grass.itc.it/grass57/binary/mswindows_cygwin
download:
xtcltk-8.3.4-CYGWIN.tar.gz
You can use Cygwin setup to un-install any existing Cygwin version of
Tcl/Tk, or you can use some other method to hide it. You can issue the
command 'which wish' to see which version Grass is finding, or 'which -a
wish' to see all versions of wish which are installed. (wish is a
component of Tcl/Tk).
I have no idea what's with the "cygwinb19.dll", I don't have one on my
system.
Rich
Richard Greenwood
www.greenwoodmap.com
--__--__--
Message: 5
Date: Sun, 10 Oct 2004 03:17:04 +0200
To: Richard Greenwood <rich at greenwoodmap.com>
>>> locate
>>> problem"
>>> Any ideas?
>> Gerrit
> found at:
> download:
> system.
If this TCL/TK depends on a 5 years old version of Cygwin, then good
night, I'm sure that there are more than one ports of recent TCL
packages to recent Cygwin versions out there in the web, so why should
one use a beta version which b19 is (that was the beta before beta20).
We have five years later and Cygwin is at version 1.5, no beta, more
stable IMO.
In the document at the website you quopted is stated:
"Prerequisites:
- Cygwin, latest release,"
No word about b19, I assume the TCL package is broken, ask the maintainer.
And could you tell me who is this maintainer and what is the difference
with this TCL package?
Gerrit
--__--__--
Message: 6
Date: Sun, 10 Oct 2004 10:37:50 +0200
CC: Richard Greenwood <rich at greenwoodmap.com>, mperra at petrelrob.com
> "Prerequisites:
Is it eventually the MySQL client which is requireing cygwinB19?
You may fetch my MySQL package then which is compiled against recent
Cygwin DLL:
http://anfaenger.de/cygwin/cygwin-1.5/mysql/mysql-4.0.17-pc-cygwin-i686-1.ta
r.bz2
There is the server included in this huge package, just move mysql.exe
and the cygmysqlclient-x.dll to a directory in your PATH (e.g.
/usr/local/bin).
Gerrit
--__--__--
winGRASS at grass.itc.it
End of winGRASS Digest
More information about the grass-windows
