[winGRASS] Getting GRASS to run?
Stephen Clark stephen.clark at focus.ca
Wed Oct 20 17:46:40 EDT 2004
Try this:
> In cygwin, launch the XFree86 server at Cygwin Bash prompt with:
> export DISPLAY=127.0.0.1:0
> XWin -multiwindow  -clipboard &
> Now the X Server is listening and will open X related windows in
individual
> windows. Then start GRASS as usual:
> grass5
> d.mon x0
> d.mon sel=x0
and for reference:
> > > Could someone post some links to installing Grass 5.3 under Cygwin.
> > Some notes here:
> > http://www.geog.uni-hannover.de/grass/grass53/binary/mswindows_cygwin/
> > and also item 1 here:
http://www.geog.uni-hannover.de/grass/grass50/binary/windows_cygnus/cygwin_grass50bininstall.html
> > has the list of Cygwin packages you need to install, which is important.
Stephen
----- Original Message -----
From: "Jonathan Christensen" <dzhonatan at gmail.com>
To: <wingrass at grass.itc.it>
Sent: Wednesday, October 20, 2004 2:29 PM
Subject: [winGRASS] Getting GRASS to run?
> Hey all,
> I recently came across GRASS and decided to give it a try--I'm a
> GIS/CG hobbyist--but have had some trouble getting it to work. I
> followed the directions on
http://grass.baylor.edu//grass57/binary/mswindows_cygwin/cygwin_grass.html,
> and everything seems to work fine until I get to the bit where it
> says:
> "First open an xterm (terminal window):
> startx"
> cygwin says that the startx command isn't recognized. After messing
> around a bit, I found that just 'x' opens a window of some kind, but
> then I see no way to open GRASS. If I try just entering grass57, I get
> the following:
> $ grass57
> Application initialization failed: no display name and no $DISPLAY
environment v
> ariable
> Searching for web browser, but neither konqueror, nor mozilla, opera,
netscape f
> ound.
> WELCOME TO GRASS              Version 5.7.0         2004
>    1) Have at your side all available GRASS tutorials
>    2) When working on your location, the following materials
>       are extremely useful:
>       - A topo map of your area
>       - Current catalog of available computer maps
>    3) Check the GRASS webpages for feedback mailinglists and more:
>       http://grass.itc.it/
>       http://grass.ibiblio.edu/
> Hit RETURN to continue
> [I hit RETURN...]
> /usr/local/grass5.7.0-i686-pc-cygwin-24_06_2004/etc/Init.sh: cannot create
/tmp/
> grass57-The Dude-19784/gisrc: directory nonexistent
> And nothing more happens.
> Anybody know what's wrong? I don't have a clue where to start, so any
> help would be greatly appreciated.
> Thanks!
> winGRASS mailing list
> winGRASS at grass.itc.it
> http://grass.itc.it/mailman/listinfo/wingrass
More information about the grass-windows mailing list
