[winGRASS] grass native installation problem
Jonathan Aguero jua130 at psu.edu
Sat Dec 2 14:24:13 EST 2006
Brian and Jacques,
I just had the same problem with my WinXP system. It seems that the problem
was related to my old Cygwin installation. I removed cygwin and clean up the
environmental variables related and then GRASS worked.
If the CYGWIN variable is defined in your system, the grass init script
assumes that the shell is bash instead of the bourne shell (sh) used by
MINGW/msys.
I hope this help you guys.
Jonathan Aguero Valverde
Research Assistant and Ph.D. Candidate
Pennsylvania State University
The Pennsylvania Transportation Institute
201 Transportation Research Building
University Park, PA 16802
www.personal.psu.edu/jua130
-----Original Message-----
From: wingrass-bounces at grass.itc.it [mailto:wingrass-bounces at grass.itc.it]
On Behalf Of Bryan Keith
Sent: Monday, October 02, 2006 10:12 AM
To: Jack
Cc: wingrass at grass.itc.it
Subject: Re: [winGRASS] grass native installation problem
I'm having the exact same problem.  Anyone know how to solve it?
Bryan
Jacques Charroy wrote:
> Hi,
> I recently installed the native wingrass package on two computers. On
> one everything went well, but on the next one gis.m never managed to
> start, although GRASS starts alright. Upon starting gis.m I get an error
> box saying the following:
> Error in startup script
> Can't read "parts(n)": no such variable
> while executing
> "MapCanvas::zoom_new $mon $parts(n) $parts(s).......(more)
> (procedure "MapCanvas::zoom_gregion" line 11)
> invoked from within.......and so forth with 5 or six levels of function
> calls until:
> invoked from within
> (file "C:/msys/1.0/local/grass/etc/gm/gm.tcl" line 522)
> Has someone else had the same problem? any ideas how to solve that?
> Thanks,
> Jacques Charroy
> winGRASS mailing list
> winGRASS at grass.itc.it
> http://grass.itc.it/mailman/listinfo/wingrass
More information about the grass-windows mailing list
