[winGRASS] wish command does not work
Mareike Hirschfeld m_hirschfeld at gmx.net
Fri Dec 8 09:50:37 EST 2006
hello,
I tried to install GRASS using MinGW, Msys, tcltk and Postgres as explained at http://geni.ath.cx/grass.html#toc2 the installation looks fine so far but when I start the grass.bat I get:
warning: The wish command does not work as expected!
Please check your GRASS_WISH environment variable.
and just a command line - how do I fix the wish command?
I found a few mails concerning wish problems but I did not understand how to solve my problem.
thanks in advance, Mareike
Der GMX SmartSurfer hilft bis zu 70% Ihrer Onlinekosten zu sparen!
Ideal für Modem und ISDN: http://www.gmx.net/de/go/smartsurfer
More information about the grass-windows mailing list
