[winGRASS] not importing blue band of geotiff- maybe to do with 16 versus 8 bit files
Natalie O'Toole notoole at mtroyal.ca
Fri Feb 24 17:04:49 EST 2006
I had a thought. Maybe this is not working because I'm using a 16-bit
geotiff and GRASS imports only 8-bit. Does anyone know how to change from
16-bit to 8-bit in GRASS?
Thanks,
Natalie
__________________
I'm using the GRASS import function to import a 3-band Quickbird image.
I've tried to import it as a geotiff, an ERDAS file, and an ESRI grid. My
problem is that in all of these formats the blue band will not import-
GRASS just hangs up when it gets to the band 3 point in the import. Does
anyone know how to fix this?
Thanks,
Natalie
URL: http://lists.osgeo.org/pipermail/grass-windows/attachments/20060224/2cf4e0b5/attachment.html
More information about the grass-windows mailing list
