[GRASS-windows] Re: [Qgis-user] [Qgis-developer] GRASS DBF driver broken in QGIS 0.9.1 [was: New Installer for Qgis 0.9.1 for Windows]
Jonathan Aguero-Valverde jua130 at psu.edu
Wed Dec 12 09:27:24 EST 2007
Listers,
I can confirm the dbf problem in QGIS/GRASS. I am running QGIS 0.9.0
26.10.2007 build. My OS is Vista but I don't think it matters. I am also
running WINGRASS 6.3RC3 and I got the same problem so something is broken in
winGRASS now. See the error messages for more info. The messages are from
the CLI from within QGIS
    $ db.connect -p
    driver:dbf
    database:$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/
    schema:
    group:
The connection set up looks fine to me, but if you try getting info in a
specific layer:
    $ v.db.connect map=dist2_net3 -c
    Invalid argument: can't _spawnl
    GRASS_INFO_ERROR(260,1): Unable to start driver <dbf>
    GRASS_INFO_END(260,1)
If I try db.describe from winGRASS I get this:
    db.describe -c table=dist2_net3 driver=dbf
{database=$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/}
    invalid argument: can't _spawnl
Research Assistant and Ph.D. Candidate
Pennsylvania State University
The Pennsylvania Transportation Institute
201 Transportation Research Building
University Park, PA 16802
www.personal.psu.edu/jua130
----- Original Message -----
From: "Richard Duivenvoorde" <rdmailings at duif.net>
To: "Maciej Sieczka" <tutey at o2.pl>
Cc: <qgis-developer at qgis.org>; <tisham at apogee.com.au>; "qgis-user"
<qgis-user at qgis.org>
Sent: Wednesday, December 12, 2007 3:20 AM
Subject: Re: [Qgis-user] [Qgis-developer] GRASS DBF driver broken in QGIS
> I'm using qgis on windows, (normally not using grass though). If someone
> provides a small 'test' description and eventually a download url for
> the build, it's no problem for me to do some testing.
> Regards
> Maciej Sieczka wrote:
>> Jürgen E. Fischer wrote:
>>> I found a problem today when using the GRASS dbf driver from the MSVC
>>> build.
>>> QGIS failed to use the dbf driver and therefore the attribute table was
>>> empty.  I considered this a MSVC problem only, but maybe it's not.
>>> Do you see attributes in the attribute table in QGIS?
>> Hi Jürgen
>> I'm not using Windows. I might have a chance to try on
>> another box, but can't say for sure. Windows QGIS users
>> please step forward.
>> Maciek
>> Qgis-user mailing list
>> Qgis-user at lists.qgis.org
>> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-user
More information about the grass-windows mailing list
