[winGRASS] Re: [OSM-talk] Regarding using osm2pgsql for winGRASS
yuri bay ksh_wong at msn.com
Wed Feb 7 07:47:21 EST 2007
Hi Artem,
I am trying to compile the osm2pgsql.c using Msys in win2k (to be used for
winGRASS) and the following is part of the list of errors.  I have put both
the libxml/ xmlstring.h and libxml/ xmlreader.h files into the same
directory as the one with osm2psql.c  in.  What seem to be the problem here?
  Where should I put my libxml.dll and why is the compiler not recognise
these files?
error*********************************
libxml/ xmlstring.h: No such file or directory
libxml/ xmlreader.h: No such file or directory
parse error before "reader"
In function: 'StartElement':
'xmlChar' undeclared (first use in this function)
Any advice and suggestions is much appreciated.  Many thanks
best regards
Casey Wong
>From: Artem Pavlenko <artem at pavlenko.uklinux.net>
>To: "yuri bay" <ksh_wong at msn.com>
>Subject: Re: [OSM-talk] How to convert OSM into GML - stuffs installed
>Date: Tue, 6 Feb 2007 13:54:28 +0000
>Yes, you should be able to compile osm2pgsql in win32. You'll need
>libxml.dll
>( try gnuwin32 on sourceforge).
>Cheers,
>Artem
>On Tuesday 06 February 2007 10:49, yuri bay wrote:
> > Artem,
> > By the way I also have these installed:
> > 1) Postgresql/postgis
> > 2) MinGW
> > 3) Msys
> > 4) winGRASS
> > Many thanks
> > regards
> > Casey
> > >CC: talk at openstreetmap.org
> > >Subject: Re: [OSM-talk] How to convert OSM into GML - examples needed
> > >Date: Tue, 6 Feb 2007 09:37:32 +0000
> > >Casey,
> > >I'm assuming you're on a Linux box  and you have postgresql/postgis
> > >installed
> > >(see http://www.postgresql.org http://www.postgis.org for howto)
> > >1.  Get the source
> > >svn co http://svn.openstreetmap.org/utils/osm2pgsql
> > >2. cd ./osm2pgsql
> > >     make
> > >  ( You might have to modify Makefile to fit your settings)
> > >3.   ./osm2pgsql planet.osm  > planet.sql
> > >You can then load planet.sql into postgresql :
> > >psql -Uusername dbname  < planet.sql
> > >4. I dont use GRASS myself but I'm pretty sure it would let you connect
>to
> > >postgis db and load osm data. You can also use ogr2ogr utility to
>convert
> > >postgis table into something else e.g shapefiles . Just google for
> > > gdal/ogr
> > >Cheers
> > >Artem
> > >On Tuesday 06 February 2007 09:13, yuri bay wrote:
> > > > Artem,
> > > > Many thanks for your reply.  I am very interested to learn more,
>would
> > >you
> > > > mind letting me know more detail about the step involves, for
>instance,
> > > > where do I go to load OSM into postgresql/postgis, I mean where do I
> > > > put the file osm2pgsql.c and what do I do with it?  And then how /
> > > > where do
> > >I
> > > > read it into GRASS.  Sorry but I am newbie in this and your help is
> > > > much appreciated!
> > > > Best Regards
> > > > Casey
> > > > >To: talk at openstreetmap.org
> > > > >CC: "yuri bay" <ksh_wong at msn.com>
>needed
> > > > >Date: Mon, 5 Feb 2007 18:23:18 +0000
> > > > >You can load planet.osm into postgresql/postgis with osm2pgsql.c
> > > > >Then read direclty into Grass or export to GML/KML/Shapefiles
>whatever
> > > > >using
> > > > >PostGIS native functionality or ogr2ogr
> > > > >Cheers
> > > > >Artem
> > > > >On Monday 05 February 2007 17:37, yuri bay wrote:
> > > > > > Hi,
> > > > > > Does anyone know where can I find examples on how (i.e. the
>steps
> > > > >involve
> > > > > > in) to convert OSM into GML?  Is this the best way to import OSM
> > >into
> > > > > > GRASS? I am using WinGRASS on win2k.  I have the OSM dataset
> > > > >(planet.osm)
> > > > > > but not sure what to do with it.  How can I start to convert it
> > > > > > into
> > > > >GML?
> > > > > > Do I need any other software, script editor or programming
>language
> > > > > > such
> > > > >as
> > > > > > C ? Your help is much appreciated.
> > > > > > Regards
> > > > > > Casey Wong
>_________________________________________________________________
> > > > > > MSN Hotmail is evolving  check out the new Windows Live Mail
> > > > > > http://ideas.live.com
> > > > Click Here To Find Your Perfect Match This Valentines!
> > > > http://msnuk.match.com/
Get Hotmail, News, Sport and Entertainment from MSN on your mobile.
http://www.msn.txt4content.com/
More information about the grass-windows mailing list
