[winGRASS] Re: [GRASS-user] Re: Xganim errors in WinGRASS
Wed Feb 7 16:33:45 EST 2007
yuri bay wrote:
> If I need to use the solution you have suggested, does that mean I
> need to uninstall the native binary winGRASS so that I can install
> the Cygwin binary one?? I have tried to use d.slide.show but there is
> no response nor errors.
Sorry, I don't know much about installing GRASS on Windows. Hopefully
someone else can answer?
d.slide.show will need an X-monitor to run, and that is only available
with X-Windows from the Cygwin.
Hamish
More information about the grass-windows mailing list
