[winGRASS] Re: Cygwin winGRASS 6.2 errors
yuri bay ksh_wong at msn.com
Mon Feb 12 07:41:20 EST 2007
Dear Glynn,
I have encountered the following error when I first time invoked the Cygwin
winGRASS 6.2 after I have successfully installed it.  I am using both native
binary and the new cygwin 6.2 winGRASS.  I have copy and past my GRASSDATA
dir into cygwin directory so that I can access the same data using cygwin
winGRASS.  But when I have selected the correct directory and mapset, the
following error occured on the xwindow:
GRASS 6.2.1 (L_UK):~ > child process exited abnormally, by using gis.m on
the xwin will give the same error.
L_UK is my mapset, what could have cause this error, your help is much
appreciated.
Thanks
Casey Wong
>From: Glynn Clements <glynn at gclements.plus.com>
>To: "yuri bay" <ksh_wong at msn.com>
>CC: grassuser at grass.itc.it, wingrass at grass.itc.it
>Subject: Re: [winGRASS] Re: Need uninstall native winGRASS for 6.2
>CygwinwinGRASS??
>Date: Sun, 11 Feb 2007 20:30:19 +0000
>yuri bay wrote:
> > Do I need to uninstall my current winGRASS native binary version if I
>want
> > to install the 6.2 Cygwin winGRASS?
>No.
_________________________________________________________________
Have you tried Windows Live Spaces? Tell us what you think!
https://www.msnfeedback.com/perseus/surveys/961278308/6653c632.htm
More information about the grass-windows mailing list
