[winGRASS] Re: [GRASS-user] Re: Cygwin winGRASS 6.2 Errors!
yuri bay ksh_wong at msn.com
Wed Feb 14 04:22:43 EST 2007
Thanks for your reply.  I have extracted the gdal into the cygwin root
directory again, eventhough I believed they have been installed when I
install the grass62 package with setup.ini, i.e. the /usr/local/bin/ shows
some gdal*.exe and tcl*.exe files.  When I tried to invoke grass by
selecting the mapset, the same error (child process exited abnormally)
occurs.  I then tried re-install the grass62 again (the package downloaded
from cygwin setup).  But it said the following:
The setup.ini used is older than the previous one, proceed anyway?
Does this affect the installation process??
Please help
Thanks
Casey Wong
>From: Michael Barton <michael.barton at asu.edu>
>To: yuri bay <ksh_wong at msn.com>, Hamish <hamish_nospam at yahoo.com>
>CC: <grassuser at grass.itc.it>, <wingrass at grass.itc.it>
>Subject: Re: [GRASS-user] Re: Cygwin winGRASS 6.2 Errors!
>Date: Tue, 13 Feb 2007 15:00:40 -0700
>If you are getting nothing when you type g.region -p, there is something
>wrong with your installation. One issue that seems to come up more
>frequently is that there is some problem with the gdal installation.
>Michael
>On 2/13/07 10:24 AM, "yuri bay" <ksh_wong at msn.com> wrote:
> > To Hamish and everyone,
> >> From: Hamish <hamish_nospam at yahoo.com>
> >> To: "yuri bay" <ksh_wong at msn.com>
> >> CC: grassuser at grass.itc.it, wingrass at grass.itc.it
> >> Subject: Re: [GRASS-user] Re: Cygwin winGRASS 6.2 errors
> >> Date: Tue, 13 Feb 2007 12:34:17 +1300
> >> yuri bay wrote:
> >>> I have encountered the following error when I first time invoked the
> >>> Cygwin  winGRASS 6.2 after I have successfully installed it.  I am
> >>> using both native  binary and the new cygwin 6.2 winGRASS.  I have
> >>> copy and past my GRASSDATA  dir into cygwin directory so that I can
> >>> access the same data using cygwin  winGRASS.  But when I have selected
> >>> the correct directory and mapset, the  following error occured on the
> >>> xwindow:
> >>> GRASS 6.2.1 (L_UK):~ > child process exited abnormally, by using gis.m
> >>> on the xwin will give the same error.
> >> what does it say if you type "g.region -p" at that prompt?
> >> "d.mon x0" ?
> >> "gis.m" ?
> > With gis.m or "gis.m" the results are the same, child process exited
> > abnormally
> > With d.mon x0, a monitor is activated.
> > With g.region -p, there is no respond or error
> > and for all the child process errors shown on the Xwindow, the errors
>shown
> > in the Cygwin command prompt is:
> > winMultiWindowxMsgProcErrorHandler - Error: Badwindow (invalid Window
> > parameter)
> > What seem to be the problem?? why can I open a mapset within a location
>in
> > the grass_data directory when they are properly configured?
> > Any help is much appreciated.
> > Regards
> > Casey Wong
> > _________________________________________________________________
> > Click Here To Find Your Perfect Match This Valentines!
> > http://msnuk.match.com/
>Michael Barton, Professor of Anthropology
>School of Human Evolution & Social Change
>Center for Social Dynamics & Complexity
>Arizona State University
>phone: 480-965-6213
>fax: 480-965-7671
>www: http://www.public.asu.edu/~cmbarton
MSN Hotmail is evolving – check out the new Windows Live Mail
http://ideas.live.com
More information about the grass-windows mailing list
