[winGRASS] m.in.e00 63_cvs20070615
Markus Neteler neteler at itc.it
Sun Jun 24 14:54:47 EDT 2007
Howard Webb wrote:
> I just downloaded and installed the latest.  Definitely some improvements.
> For the most part, so far, it all seems to be working well.  Thank for all
> the work.
> I am trying to import some DEM files that appear to be in e00 raster
> format (via http://www.msdis.missouri.edu/data/dem/index.htm#).
> It looks like I should be able to import this via m.in.e00, but the module
> seems to be missing (not in the bin directory).  Is this a bug issue with
> this module (hence left out of this build), the module is missing, or has
> there been a replacement for this functionality?
> Thanks,
> Howard
Howard,
so far nobody ported m.in.e00/raster to GRASS 6. In general, it would be
better to
add such functionality to GDAL (and then use r.in.gdal). Could you post this
as
wish to GDAL at www.gdal.org?
Markus
View this message in context: http://www.nabble.com/m.in.e00-63_cvs20070615-tf3943855.html#a11277374
Sent from the Grass - Win mailing list archive at Nabble.com.
More information about the grass-windows mailing list
