[winGRASS] winGRASS: some test results
Moritz Lennert mlennert at club.worldonline.be
Fri May 18 10:35:00 EDT 2007
Hello,
Here are some (somehwat random) issues I came across with the latest
version. I find the first one a bit mysterious as it used to be working
and I don't see what has changed since...
Moritz
Testing WinGRASS, CVS 16/5/2007
1) error at startup:
In terminal window:
access: Invalid argument
ERROR: LOCATION << C:/GRASS/bin/<UNKNOWN> >> not available
Then in GUI startup window:
Warning: location <<UNKNOWN>> at GISDBASE <C:/GRASS/bin> is not a directory or does not exist
I can then navigate to my GRASSDATA directory and enter spearfish location.
My .grassrc6 is in %USERPROFILE% directory and contains (before launching GRASS):
GISDBASE: C:/GRASSDATA
LOCATION_NAME: spearfish60
MAPSET: user1
2)cell values display layer
I always get error: "Cell values can only be displayed for regions of < 10,000 cells, even if g.region -p:
rows:       56
cols:       75
cells:      4200
3) wish: Would be great if the windows terminal window could be closed.
4) text layer, chosing fonts: 'couldn't execute "uname": no such file or directory'
5) nviz: 'couldn't execute "nviz": no such file or directory'
6) Vector -> Develop map -> Digitize:
child killed: SIGABRT
    while executing
"exec -- $program --tcltk"
    (procedure "run_ui" line 6)
    invoked from within
"run_ui $cmd"
    (procedure "execute" line 3)
    invoked from within
"execute v.digit "
7) Help is still not available from module dialog windows, or from help menu
More information about the grass-windows mailing list
