[winGRASS] v.in.db command using PostgreSQL database
ante_anzulovic ante_anzulovic at net.hr
Thu May 24 06:26:54 EDT 2007
I'm having a problem with extracting vector data from my PostgreSQL database.
this is the set of commands that work fine:
>db.connect driver=pg database="host=localhost,dbname=projekt"
>db.login user=zmija pass=********
>db.connect -p
driver:pg
database:host=localhost,dbname=projekt
schema:(null)
group:(null)
So, now I have a valid connection to my database, GRASS recognizes it, and I checked with other
commands (db.columns, db.tables).
I have to extract vector data from database, but after using the command:
> v.in.db driver=pg database="host=localhost, dbname=projekt"  table=public.teren x=xorig y=yorig
z=zorig key=ID out=teren2 --overwrite
WARNING: The vector 'teren2' already exists and will be overwritten.
DBMI-Postgres driver error:
Cannot connect to Postgres: fe_sendauth: no password supplied
WARNING: Cannot open database 'host=localhost, dbname=projekt'
ERROR: Cannot open database <host=localhost,dbname=projekt> by driver <pg>
the driver couldn't be bad because it's used for connecting to database, and that works
how can I supply a password to v.in.db if it requires it?
please help...
Ante
Iskon.DUO - vrtoglavo brz ADSL do 10 Mbps u paketu s telefonom za 99 kn/mj.
Saznajte vise na www.iskon.hr ili putem telefona 0800 1000.
More information about the grass-windows mailing list
