[winGRASS] v.in.db command using PostgreSQL database
Moritz Lennert mlennert at club.worldonline.be
Thu May 24 09:38:36 EDT 2007
On 24/05/07 15:05, ante_anzulovic wrote:
>> try db.login.
> I tried using db.login and all I got was
>> WARNING: The password was stored in file.
This is normal.
> nothing changed about v.in.db command, I still get the same error message
i.e. "Cannot connect to Postgres: fe_sendauth: no password supplied" ?
In your previous mail you said:
> So, now I have a valid connection to my database, GRASS recognizes it, and I checked with other
> commands (db.columns, db.tables).
So no password issue for those modules ?
>> For the future: when you report a problem, please indicate which version
>> of GRASS you are using on which platform.
> Sorry, I'm using native WinGRASS and also GRASS 6.2.1 installed on Cygwin, on both versions I get
> same results
I'll test on windows tonight to see if I can reproduce this.
Moritz
More information about the grass-windows mailing list
