[winGRASS] Re: [GRASS-user] grass.bat script for Cygwin GRASS 6.2.2-1
Luigi Ponti lponti at infinito.it
Mon Sep 3 14:44:24 EDT 2007
Hamish wrote:
> Luigi Ponti wrote:
>>>> Installation instructions at
>>>> <http://grass.itc.it/grass62/binary/mswindows/>
>>>> Starting GRASS ...
>>>> Application initialization failed: this isn't a Tk
>>>> applicationcouldn't connect to display "localhost:0"
>>>> Error in startup script: dynamic loading is not currently available
>>>> on this system
>>>>     while executing
>>>> "load /usr/local/lib/tk8.4/../libtk8.4.a Tk"
> Hamish:
>>> Did you modify the bash line to run startx, launching X at startup?
>>>   bash --login -i -c startx
>> Yes, I did. Here is my cygwin_grass.bat file:
>> the next thing I see is the GRASS startup message
>>     Cleaning up temporary files.....
>>     Starting GRASS ...
>> And no X runs. GRASS starts in text mode but then it tries to load a
>> GUI and off course this fails.
> No idea as to what is going wrong.
> The plan is that cygwin starts X11 on startup (-c startx) in the cygwin
> dos-box; then X11 opens a xterm when it starts; and that xterm launches
> grass. The '-n "$DISPLAY"' part should protect against it trying to start
> grass from the cygwin dos-box outside of X11. What does:
>   echo $DISPLAY
> say from the cygwin dos-box prompt (not the xterm).
> Hamish
It says
    127.0.0.1:0.0
Nice cue: I had a $DISPLAY set via the winXP control panel that was
apparently interfering with the
    if [ -n "$DISPLAY" ] && [ -n "$GRASS_AUTOSTART" ] ; then
switch at the bottom of .bashrc (this is probably why GRASS would start
before the XTerm was running, as you said. Now I understand the
rationale behind it).
As an aside, if I run a cygwin_grass_modified.bat script that is
basically grass61.bat (and all related environmental variables that are
set therein) except that I deleted the
    run xterm ...
line and added
    set GRASS_AUTOSTART=1
what happens is that GRASS runs inside dos-box (or at least this what
the shell looks like -- the title bar says
"C:\WINDOWS\system32\cmd.exe") but since there is an X Server running,
the GUI loads OK and faster than with the regular cygwin_grass.bat file.
Apparently, the lower loading time is due to no XTerm starting up in the
latter case -- there is only one shell open. Don't know if this can be
of any use.
Unrelated thing: in the process I also found out that in order for the
g.manual script to display cygwin/GRASS HTML help files, the cygwin_root
environmental variable needs to be set up in cygwin_grass.bat
    SET CYGWIN_ROOT=c:\cygwin
otherwise it is empty (it used to be set up by grass61.bat, but not by
cygwin_grass.bat) when g.manual calls it. (Again, from a previous post,
there is a lot of missing HTML help files in the version I downloaded --
6.2.2-1: is it just a download error?)
Thanks and regards,
Luigi
URL: http://lists.osgeo.org/pipermail/grass-windows/attachments/20070903/e8cb8a64/attachment.html
More information about the grass-windows mailing list
