[GRASS-windows] Colour code vector maps
Moritz Lennert mlennert at club.worldonline.be
Thu Aug 14 06:01:45 EDT 2008
On 14/08/08 11:21, Arran_Jay wrote:
>> How did you launch d.vect.thematic. AFAIR, d.vect.thematic should work
>> in the GUI, i.e. using the 'Add thematic layer' button. If you want to
>> call d.vect.thematic from a command line, use the -s flag, so that it
>> doesn't use monitors.
>> If you don't get a nice legend in the GUI, you can use the psmap=
>> parameter to create a ps.map instruction files, one for the map and one
>> for the legend
> When I try and add a vector layer through the GUI I get the error message:
> dirname: extra operand `and'
> Try `dirname --help' for more information.
> cp: target `/gismlegend.txt' is not a directory
> rm: cannot remove directory `d:/documents': Is a directory
> Then the monitor loads up a blank screen and I get a blank legend box.
This is a quoting problem. Don't have time to look at this and leaving
on vacation tomorrow, but forwarding to Michael (who is also very
busy...) who wrote the script...
Moritz
More information about the grass-windows mailing list
