[GRASS-windows] d.rast, d.vect errors
Fri Aug 15 02:06:19 EDT 2008
Carolyn Chan wrote:
> A warning: I know very little about any of this.
> I downloaded WinGRASS by just running the .exe installer file, and I
> chose to include all sample data sets.  I was given the 3rd ed. GRASS
> test to work through.  I find I am having problems with very basic
> things that no one else on the internet seems to find problematic.
> So first main issue: d.rast and d.vect both give
> PNG: GRASS_TRUECOLOR status: TRUE
> PNG: collecting to file: C:/Documents and Settings/.../user1/.tmp/8576.0.ppm,
>      GRASS_WIDTH=538, GRASS_HEIGHT=484
> I read that GRASS_WIDTH and GRASS_HEIGHT are environment variables, and
> can be set in the command prompt using set VARIABLE=VALUE.  Unsure of
> what directory I should be in, I went for C:\GRASS set
> GRASS_WIDTH=1500 [# of columns in the region I wanted... that was a
> guess.], same for GRASS_HEIGHT=1350.
> Trying the d.rast elevation again gave me no noticable difference except
> for a lime green bar across the top of the error message.  Restarting
> GRASS, I noticed that the message had changed; now it had
> GRASS_WIDTH=525, GRASS_HEIGHT=484.
> Help?
Are you running d.vect/d.rast from the command prompt, or the GUI?
Setting a variable from the command prompt will only affect d.*
commands which are run from that prompt. For the GUI, the image size
is determined by the size of the GUI's map display window.
More information about the grass-windows mailing list
