[GRASS-windows] Problem with v.rast.stats
Gonzalo Moreno gmorenovergara at gmail.com
Tue Aug 19 05:07:55 EDT 2008
Hello.
I have a lot of polygons in a vector layer and a DTM (raster). I want to
know the maximum, minimum and mean height (of the DTM) for each polygon. I'm
trying to use the command *v.rast.stats* (update areas attributes from
raster). It starts working but at the end shows the next message:
C:/GRASS/scripts/v.rast.stats: *r.cats*: command not found
No categories found in raster map.
If I run "r.cats help", the program says that this module has been replaced
by *r.category*
I'm using GRASS6.3.0 for windows.
How can I solve this problem?
Thank you.
Gonzalo Moreno.
------------ próxima parte ------------
Se ha borrado un adjunto en formato HTML...
URL: http://lists.osgeo.org/pipermail/grass-windows/attachments/20080819/80f62cff/attachment.html
More information about the grass-windows mailing list
