[GRASS-windows] Wingrass-6.0.3-4-Setup.exe
Ted Nebitko tnebitko at can.rogers.com
Tue Aug 26 08:17:19 EDT 2008
Thanks for the reply. It appears to start correctly with both the command
line and msys console.
Welcome to GRASS 6.3.0 (2008)
GRASS homepage:                          http://grass.itc.it/
This version running thru:               Windows Command Shell (cmd.exe)
When ready to quit enter:                exit
Help is available with the command:      g.manual -i
See the licence terms with:              g.version -c
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
GRASS 6.3.0 (spearfish60):D:\Documents and Settings\T Nebitko\My
Documents\My Do
cuments\GIS DataBase\demolocation >g.region -p
projection: 1 (UTM)
zone:       13
datum:      nad27
ellipsoid:  clark66
north:      4928010
south:      4913700
west:       589980
east:       609000
nsres:      30
ewres:      30
rows:       477
cols:       634
cells:      302418
Documents\My Do
----- Original Message -----
To: <tnebitko at can.rogers.com>
Cc: <grass-windows at lists.osgeo.org>
Sent: Tuesday, August 26, 2008 5:05 AM
Subject: Re: [GRASS-windows] Wingrass-6.0.3-4-Setup.exe
> On Mon, Aug 25, 2008 at 4:24 PM, Ted Nebitko <tnebitko at can.rogers.com>
> wrote:
>> The following error appears upon entering the gis manager (using
>> Spearfish60, permanent)
>> Error setting region (Problem with g.region?): child killed unknown
>> signal
>> can't read "parts(w)": no such variable
>> while executing
>> "set $parts(w) [expr round9$parts(w)/$parts(ewres))*$parts(ewres)]*
>> (procedure "MapCanvass::zoom_gregion" line 16)
>> involved from within.............................
>> Any help is appreciated
> This error usually pops up when GDAL is somehow broken on the
> system.
> what does
> g.region -p
> say? You would need to go to the command line of GRASS for this:
> http://grass.osgeo.org/grass63/binary/mswindows/native/#Launching%20GRASS
> -> Click on this icon to launch GRASS in text mode on the Windows command
> line.
> Markus
More information about the grass-windows mailing list
