[GRASS-windows] v.6.4 regex compilation problem
Robert Szczepanek robert at szczepanek.pl
Tue Dec 30 13:01:55 EST 2008
Thanks Markus,
> the regex stuff was added as test (AFAIR). On grass-dev, there was
> a related posting:
> >> TODO:
> >> * compile with regex
> > I can report it works fine with the Gnuwin32 regex packages.
> Perhaps you could try this and report back?
> Markus
Having no experience with packages I did at the moment just
--without-regex
and
Finished compilation: Tue Dec 30 17:45:59 GMT 2008
Errors in:
/usr/local/src/grass-6.4.0/raster/r.li/r.li.daemon
/usr/local/src/grass-6.4.0/raster/r.li/r.li.edgedensity
/usr/local/src/grass-6.4.0/raster/r.li/r.li.patchdensity
/usr/local/src/grass-6.4.0/raster/r.li/r.li.patchnum
/usr/local/src/grass-6.4.0/raster/r.li/r.li.shape
/usr/local/src/grass-6.4.0/raster/r.li/r.li.simpson
/usr/local/src/grass-6.4.0/raster/r.li/r.li.shannon
/usr/local/src/grass-6.4.0/raster/r.li/r.li.mps
/usr/local/src/grass-6.4.0/raster/r.li/r.li.mpa
/usr/local/src/grass-6.4.0/raster/r.li/r.li.padcv
/usr/local/src/grass-6.4.0/raster/r.li/r.li.padsd
/usr/local/src/grass-6.4.0/raster/r.li/r.li.padrange
/usr/local/src/grass-6.4.0/raster/r.li/r.li.cwed
/usr/local/src/grass-6.4.0/raster/r.li/r.li.richness
/usr/local/src/grass-6.4.0/raster/r.li/r.li.dominance
Robert
More information about the grass-windows mailing list
