[GRASS-windows] native grass63RC4 and MSYS shell
Moritz Lennert mlennert at club.worldonline.be
Mon Feb 11 14:26:53 EST 2008
On 11/02/08 16:39, Mirko Baruffini wrote:
> Thank you Moritz!
> Now it works! I have modified the file bin/grass63 as you told me. But
> the scipts run only in text mode....
> Can I also run them with a GUI?
> Can you help me?
What does not work in the GUI ? Do you get error messages ?
Moritz
> Mirko
> Moritz Lennert ha scritto:
>>>> I' m using wingrass grass63RC4. The use is ok, but, when I launch
>>>> grass63.bat, it does not load the shell msys (I have uncommented and
>>>> adapted some of the environment variables in grass/bin/grass63.bat).
>>>> So i decided to launch a script with native wingrass launching grass
>>>> from within the msys shell.
>>>> When I type /c/grass/bin/grass63 it does not load grass. On the
>>>> sceen I can read:
>>>> mirko.baruffini at ISTPC29 /
>>>> $ /c/grass63RC4/bin/grass63
>>>> /c/grass63RC4/grass-6.3.0RC4/etc/Init.sh: uname: command not found
>>>> /c/grass63RC4/grass-6.3.0RC4/etc/Init.sh: mkdir: command not found
>>>> Cannot create temporary directory! Exiting.
>>>> But the command uname exists:
>>>> $ uname
>>>> MINGW32_NT-5.1
>>>> What could  I do?
>>> AFAIK, starting GRASS or running GRASS commands from the MSys shell is
>>> unsupported under Windows.
>> No, it should work. I cannot reproduce the above error messages.
>> However, to make the current 63RC4 package work, you have to change
>> the bin/grass63 file from
>> GISBASE=c:/grass63RC4/grass-6.3.0RC4
>> to
>> GISBASE=/c/grass63RC4/grass-6.3.0RC4
>> Then it works well for me (not everything tested, though).
>>> Unfortunately, MSys shell provides an environment which is somewhere
>>> between Unix and Windows, and not entirely compatible with either. In
>>> particular, any pathnames which GRASS sees will need to be compatible
>>> with Windows, e.g. C:\path\to\file or C:/path/to/file rather than
>>> MSys' /c/path/to/file convention.
>> Well, actually, as you can see above, for launching grass you need the
>> msys style.
>>> The focus of WinGRASS is to produce a *native* Windows version. Unless
>>> you're building WinGRASS yourself, you shouldn't need MSys for
>>> anything other than running shell scripts.
>> And even then, I guess other shells would also do the trick, such as
>> Gnuwin32's shell and tools such as awk and sed. Msys is more
>> convenient as the default installation contains these tools.
>> Moritz
> grass-windows mailing list
> grass-windows at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-windows
More information about the grass-windows mailing list
