[GRASS-windows] WinGrass 6.3.0-4 Command Line on Windows Vista
Marco Pasetti marcopstt at gmail.com
Tue Jul 29 05:58:47 EDT 2008
Hi Roland,
>I have installed the latest WinGRASS-6.3.0-4-Setup.exe on a Windows Vista
>64 computer.  After a brief review, the Grass 6.3.0 GUI appears to work
>fine.  However, >when I attempt to run a command from the command line I
>get, a shell prompt, entering the command again leads to an error.  The one
>command that does not return >an error is the exit command.
Unfortunately the problem relies on the lack of support of MSYS on windows
64bit (both XP and Vista)... that means that we can't do anything!
Marco
More information about the grass-windows mailing list
