[GRASS-windows] Large file support?
Marco Pasetti marcopstt at gmail.com
Tue Jul 29 09:43:30 EDT 2008
Hi Glynn,
> Also, if the GDAL header files are installed, you can see whether LFS
> was configured from the defines at the bottom of cpl_config.h.
I attached the mentioned header
There's no reference to the LFS in that file, neither in the configure
options
what I see in the header is only a reference to LFS for 64bit platforms...
Regards,
Marco
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-windows/attachments/20080729/32dd9e76/cpl_config.obj
More information about the grass-windows mailing list
