[GRASS-windows] Large file support?
Tue Jul 29 15:43:22 EDT 2008
Glynn Clements wrote:
> If code is obtaining the file size using stat(), it isn't going to
> work on files >2GiB. You could try manually changing the last two
> defines to:
> 	/* Define to name of 64bit stat function */
> 	#define VSI_STAT64 _stat64
> 	/* Define to name of 64bit stat structure */
> 	#define VSI_STAT64_T __stat64
Glynn,
Good advice.
If it works, please file a GDAL ticket with the details,and we may be
able to add this to configure.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
More information about the grass-windows mailing list
