[GRASS-windows] HIHI i have some problem when use native windows GRASS GIS, IT CRASHED.....
Moritz Lennert mlennert at club.worldonline.be
Sun Mar 2 14:51:53 EST 2008
On 02/03/08 03:43, wu weiming wrote:
> when i  install the GRASS in XP first time ,i open it
> use the grass63.bat in C:\grass\bin,it appear the
> GRASS GIS startup form,i clear the gis DATA directory
> TEXTBOX to BLANK and close the form,after i done
> this,i restart the grass again,it appear a message in
> DOS console window,"GISDBASE not set",and appear a tcl
> blank FORM in the MIDDLE,after i close the WINDOW,it
> CRASHED,SO i reinstall all the program AGAIN,but the
> result is the same,it appear "GISBASE NOT SET",But I
> have clear all the files about grass in the
> harddisk,it still appear this message....
> when i first time run the GRASS gis ,the startup from
> is OK,but when i clear the GIS DATA DIRECTORY TEXT box
> and restart the program again,it crash,even i
> reinstall it,i can't handle this problem please help
> me.....
This is probably due to a corrupt .grassrc6 file. If you erase that the
problem should go away. We will have to find out why simply clearing the
text field corrupts the file...
Moritz
More information about the grass-windows mailing list
