[GRASS-windows] problem with v.distance in Windows
Jonathan Aguero-Valverde jua130 at psu.edu
Sat May 24 17:44:18 EDT 2008
I am experienced some trouble with v.distance in my win box. I am running
the latest version 6.3.0
my tables are in PG, my db.connect gives:
db.connect -p
driver:pg
database:host=localhost,dbname=thesisWA,port=5432
schema:public
group:
but when I run v.distance I get:
$ v.distance from=cent_g to=road_inv_d6_b dmax=5 upload=cat,dist
column=cat_ce
nt,distance
DBMI-Postgres driver error:
Cannot connect to Postgres: could not connect to server: Connection refused
(0x0000274D/10061)
        Is the server running on host "localhost" and accepting
        TCP/IP connections on port 6543?
GRASS_INFO_WARNING(4116,1): Cannot open database
'host=localhost,dbname=thesisWA,port=6543'
GRASS_INFO_END(4116,1)
GRASS_INFO_ERROR(4116,2): Unable to open database
<host=localhost,dbname=thesisWA,port=6543> by driver <pg>
GRASS_INFO_END(4116,2)
It looks like somehow the port is hardcoded to 6543 in v.distance. If I
tried db.tables -p it gives me the list of my tables so it looks like my
connection settings are fine.
PhD. Candidate
The Thomas D. Larson
Pennsylvania Transportation Institute
The Pennsylvania State University
More information about the grass-windows mailing list
