[GRASS-windows] switching to GRASS, 6.2.3 or GRASS 6.3.0?
Marco Pasetti marcopstt at gmail.com
Wed Oct 8 02:57:05 EDT 2008
Hi Glynn,
> Marco Pasetti wrote:
>> > the path name is actually:
>> > C:/Documents and Settings/Katz&Denslow
>> > I think this is what you mean by username.
>> OK. Finally we got it!
>> I believe that the "&" is the problem!
> Do you have any idea why?
> Ideally, GRASS should handle any filename which is valid for the
> current codepage (supporting Unicode filenames which use characters
> outside of the current codepage probably isn't feasible, but that
> isn't the issue here).
I believe that the problem relies at line 32 in the init.bat: if
"%HOME%"=="" set HOME=%USERPROFILE%
the & char is recognized as a command, so, if we set, for example: set
HOME=C:\Users\Marco&Glynn
we will have: 'Glynn' is not recognized as an internal or external command,
operable program or batch file. The system can not find the path specified.
I think that we could fix it putting: set HOME="%USERPROFILE%"
but unfortunately I cannot test my solution now (too much things to do to
create a new & user and reboot the machine, I'm afraid!)
Regards,
Marco
More information about the grass-windows mailing list
