[GRASS-windows] help with command line in GRASS 6.3
Moritz Lennert mlennert at club.worldonline.be
Tue Oct 14 12:15:18 EDT 2008
On 14/10/08 18:02, Michael Denslow wrote:
> Hi Moritz, List
>>> I am very new to GRASS and have been going through chapter 3 of the
>>> Neteler and Mitasova's Open Source GIS book in order to learn some
>>> basics. I can run the functions from the GUI (e.g. viewing rasters
>>> etc.) but am not able to run the commands through the command line
>>> window. I am attempting to run them from the bottom of the 'Output
>>> Window'. What I am doing wrong here?
>> You will have to be much more specific if you want us to help you. What are
>> the commands you are trying to run, what do you expect to see and what do
>> you see (i.e. error messages, etc) ?
> OK , sure. If I run the command
> g.list rast
> in the output window I get a list of rasters great! So then I get info
> about the elevation raster from the North Carolina dataset.
> r.info elevation
> Works, great. Then set the region to be displayed
> g.region rast=elevation -p
> d.erase
> seems to work, now display the raster
> d.rast elevation
no d.* will work from the output window. You cannot interact with the
gis.m Display window through commands, only through the GUI.
> I run this command and I get a green line that runs along the bottom
> of the command when it shows up in the top of the output window and
> nothing shows in the map display. Also if I try to open a display
> monitor by entering
> d.mon x0
x-monitors do not work in Windows. You have to work through the GUI, or
directly on the cmd.exe (or msys) command line (don't think this works
via the output window) using GRASS_RENDER_IMMEDIATE=TRUE.
Moritz
More information about the grass-windows mailing list
