FW: [GRASS-windows] please help - GRASS crashes at start-up
Peter Sullivan sullivan232 at hotmail.com
Fri Aug 7 23:12:03 EDT 2009
FYI -
To: neteler at osgeo.org
Subject: RE: [GRASS-windows] please help - GRASS crashes at start-up
Date: Fri, 7 Aug 2009 23:09:46 -0400
Markus,
Hi, and apologies for the much-delayed response, been off-line for a bit. I would still like to resolve the original problem. You asked if g.region works.   I'm not entirely sure how to test whether or not it does....but the sequence of error messages I get includes "g.region.exe has stopped working"  so I assume the answer is no.
I read a follow-up from another user that suggested it might be a security issue w/ vista. I will try that angle and let you know if sucessful. If you have any other thoughts I would appreciate it.
Cheers,
Pete
> Date: Sat, 4 Jul 2009 01:04:02 +0200
> Subject: Re: [GRASS-windows] please help - GRASS crashes at start-up
> From: neteler at osgeo.org
> To: sullivan232 at hotmail.com
> CC: grass-windows at lists.osgeo.org
> Hi Peter,
> does
> g.region -p
> work? That's essentially a test if GDAL works.
> Markus
> On Fri, Jun 26, 2009 at 11:20 PM, Peter Sullivan<sullivan232 at hotmail.com> wrote:
> > Hello -
> > I am trying to launch GRASS GIS 6.4.0svn(TclTk) for the first time on
> > Windows Vista-32 Home Premium, and am receiving a sequence of error messages
> > following  location/mapset window.
> > (I ran an advanced install of all applications on 6/26/09, downloaded sample
> > data sets for both SD and NC, and specified directories for location/mapset
> > as shown in the first-timse user tutorial).
> > The error occurs after I click "Enter GRASS". Program starts to launch, then
> > I get an error message:
> > I have two options: 'Check online for a solution and close' or just
> > 'close'.
> > After clicking either of above, I then get:
> > "Error setting region (Problem with g.region?): child killed: unknown
> > signal"
> > Again I get the same options to close as above, and another error message:
> > "g.proj.exe has stopped working"
> > Then a final message:
> > g.proj or projection error: child killed: unknown signal
> > An "Error in startup script" then appears, listing approx. 8
> > application/programming areas where errors seem to have occurred.
> > Then the program shuts down, except the command prompt screen remains.
> > I am not new to GIS, but have little background in programming and no idea
> > how to troubleshoot this. None of the issues or tickets within the GRASS
> > site appear to address this problem either.
> > Any suggestions out there?  I look forward to digging into the GRASS, so
> > help is greatly appreciated.
> > Thank you,
> > Pete Sullivan
> > grass-windows mailing list
> > http://lists.osgeo.org/mailman/listinfo/grass-windows
URL: http://lists.osgeo.org/pipermail/grass-windows/attachments/20090807/0f439b93/attachment.html
More information about the grass-windows mailing list
