[GRASS-windows] wingrass and ArcGIS with Python
Peter Brooks peter at timedworld.com
Sat Aug 15 05:38:56 EDT 2009
(I can't cc this to the developers list - I'm not subscribed).
I use ArcMap as well - I initially had a problem running either GRASS
or the QGIS GRASS plugin (sorry, I can't remember which) and ended up
copying the pywintypes25.dll version 2.5.212.0 file into the
windows\system32 folder (after renaming the existing version, which
was 2.5.214.0).
Hope this helps someone...
Cheers
Peter
On 14 Aug 2009 at 23:06, Helena Mitasova wrote:
For those who need to run both ArcGIS and GRASS with Python (common
situation in GIS labs), here is the solution for the reported problem
from our technical  support:
I found there are different builds of winpython 2.5 . The version
that works for both is build is 212. I found it here...
  http://sourceforge.net/projects/pywin32/files/pywin32/Build%20212/
pywin32-212.win32-py2.5.exe/download
Helena
> Message: 1
> Date: Thu, 6 Aug 2009 21:44:23 -0400
> From: Helena Mitasova <hmitaso at unity.ncsu.edu>
> Subject: [GRASS-windows] Re: [GRASS-dev] wingrass on VISSTA and XP
> 	with two	pythons To: grass-windows at lists.osgeo.org Cc: GRASS
> developers list <grass-dev at lists.osgeo.org> Message-ID:
> <E0D9ABBF-4109-46F0-A0C7-0C7F93615F6A at unity.ncsu.edu> Content-Type:
> text/plain; charset=US-ASCII; delsp=yes; format=flowed
> Just an update, in case somebody else has a similar problem -
> GRASS from OSGeo4W installer runs with nviz on the same VISTA
> computers that had the problem below.
> But we got an interesting issue with the native installer on our XP
> machines in the teaching lab. After a separate Python2.5 install
> GRASS wxpython does not run anymore
> The error message says:
> python.exe
> the procedure entry point ?
> PyWinObject_AsHABDLE@@YAHPAU_object@@PAPAX at Z
> could not be located in the dynamic link library pywintypes25.dll
> when we searched for pywintypes25.dll we got
> C:\GRASS6-6-SVN\extralib 112KB  1/11/2009
> C:\WINDOWS\system32      100KB  9/22/2006
> C:\Python25\Lib\site_packages\ 100KB 9/22/2006
> C:\GRASS6-6-SVN\Python25\Lib   112KB 1/11/2009
> so it looks like the C:\Python25\Lib\site_packages version
> is different from the one used by GRASS I asssume that the problem
> we have is that GRASS is looking into the wrong pywintypes25.dll. Is
> there a solution to this? So far it looks like removing the second
> install of Python2.5 is not an option.
> thanks,
> Helena
> On Aug 6, 2009, at 11:02 AM, Helena Mitasova wrote:
>> Has anybody installed the latest install on VISSTA?
>> we get only the first two icons and no Tcltk runs (that means no
>> nviz)
>> http://grass.osgeo.org/grass64/binary/mswindows/native/
>> WinGRASS-6.4.0SVN-r38537-1-Setup.exe
>> thanks,
>> Helena_______________________________________________
>> grass-dev mailing list
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
> grass-windows mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-windows
> End of grass-windows Digest, Vol 36, Issue 2
More information about the grass-windows mailing list
