[GRASS-windows] Help with running GRASS commands from a Window batch file
bpost benjamin.post at primordial.com
Wed Aug 19 21:47:46 EDT 2009
Hi all,
WinXP SP2
Grass installed using: WinGRASS-6.4.0SVN-r38537-1-Setup.exe
I am working on creating a simple batch file that takes in a GeoTIFF,
creates a new Location, does some work on the image and then spits out the
final product.
I started by copying the environment setup commands from
$GISBASE\grass64.bat and removed the call to $GISBASE\etc\Init.bat.
I started by adding in a call to
g.proj.exe -pc georef=<path to image> location=test
and verified that a new location named "test" was placed in my $GISDATA
directory, including the PERMANENT folder and the DEFAULT_WIND, PROJ_INFO,
PROJ_UNITS, and WIND files.
Then I added in
r.in.gdal.exe input=<path to image> output=aerial
and verified that it created aerial.red, aerial.green, aerial.blue, and
aerial.4.
When I added the command to create an RGB
r.composite.exe red=aerial.red green=aerial.green blue=aerial.blue levels=1
output=aerial
I got an error telling me to set the region using r.region.
So I added in
r.region map=aerial.red
to set the region based on the size of the red channel.
When I ran this, all of the executables started throwing unhandled
exceptions (stack overflow, divide by zero, etc.)  So I started removing
commands in the batch until only the g.proj.exe command remained and I was
still getting unhandled exceptions.
At this point I decided to restart my computer and reinstall GRASS.  Now
when I run the batch file, none of the commands do anything.  Even
g.proj.exe -help shows nothing in the command window.
Has anyone run into this, or know of a workaround/fix to this issue?
The commands all work in the GUI, so I am not sure why they won't work in a
batch file.
Thanks for your time!
Ben
View this message in context: http://n2.nabble.com/Help-with-running-GRASS-commands-from-a-Window-batch-file-tp3476392p3476392.html
Sent from the Grass - Win mailing list archive at Nabble.com.
More information about the grass-windows mailing list
