[GRASS-windows] winGRASS 6.4.0RC3 available in OSGeo4W test mode
Markus Neteler neteler at osgeo.org
Tue Feb 3 12:13:40 EST 2009
On Tue, Feb 3, 2009 at 5:26 PM, Luigi Ponti <lponti at infinito.it> wrote:
> On 28/01/2009 17.56, Markus Neteler wrote:
>> The winGRASS 6.4.0RC3 has been packaged, for now in test mode (new
>> digitizer and wxnviz yet not included):
>> To install (note the -t) run:
>> C:\osgeo4w-setup.exe -t
> Seems like it is working also without -t flag.
Meanwhile yes since they updated the standard version to RC3.
For better following the available versions, I have added to
http://trac.osgeo.org/osgeo4w/wiki/PackageListing
    * List of current package versions
    * List of current package test versions (see differences highlighted)
> After the wxpython gui is loaded, you just see the GIS map display and it is
> a bit tricky to bring the layer manager forward -- don't know if this is a
> problem, just different from the tcltk gui where you would see both windows
> at startup.
Sincerely, no idea, if nobody answers here maybe ask on grass-user.
>> The previously missing g.mlist has been included now.
> In fact, selection of map layers works fine now.
Perfect.
wxnviz and wxdigit are still failing but this will be hopefully resolved soon.
Markus
More information about the grass-windows mailing list
