[GRASS-windows] Compiling grass7 on msys/mingw?
Sun Jan 11 07:00:34 EST 2009
Colin Nielsen wrote:
> Errors also in all of the /scripts/:
> PYTHONPATH="/usr/local/src/grass_trunk/dist.i686-pc-mingw32/etc/python:$PYTHONPATH"
>     import grass
> ImportError: No module named grass
> make: *** [db.dropcol.tmp.html] Error 1
> If it's looking for the grass.py in the pythonpath, there is one there...
I suspect that Python wants PYTHONPATH to use Windows syntax, e.g.
(untested):
-	PYTHONPATH="$(GISBASE)/etc/python:$$PYTHONPATH" \
+	PYTHONPATH="$(call mkpath,$(GISBASE)/etc/python,$$PYTHONPATH)" \
+ifneq ($(MINGW32),)
+mkpath = $(shell g.dirseps -h $(1))\;$(2)
+else
+mkpath = $(1):$(2)
+endif
MinGW transparently converts filename and path syntax for environment
variables which it knows about (e.g. PATH), but probably not for
PYTHONPATH.
More information about the grass-windows mailing list
