[GRASS-windows] GRASS6.4.RC3-2 on xp 64 bit
Colin Nielsen colin.nielsen at gmail.com
Tue Mar 3 12:25:41 EST 2009
I have had the same problem on two XP 64 machines, one automatically
selected all the dependencies, the other did not. One is now up and
running with no problems, the other still won't work. I have tried to
erase the whole file tree and start again but it still doesn't work
(perhaps some hidden registry entries are responsible?).
Sorry I can't be of more help, but I would like to know if this
problem gets resolved.
-Colin
On Mon, Mar 2, 2009 at 5:37 PM, Ibrahim Mohammed
<ibrahim.mohammed at aggiemail.usu.edu> wrote:
> Yes, I am using osgeo4w installer.
> You are right libexpat is not installed as well as many others.
> When I went to the Advanced option and selected grass I realized after the
> installation only  3 libraries have been installed in C:\OSGeo4W\lib which
> are (gdal, iconv, and proj-i).
> I tried to install grass in another computer and it works fine and then by
> comparing the libraries I realized I am missing a lot.
> What do you think the cause and how to overcome that?
> I tried to copy the whole lib folder libraries but still the software is not
> booting up!!!!!
> Appreciate your help!
> Ibrahim
> On Sun, Mar 1, 2009 at 3:30 AM, Markus Neteler <neteler at osgeo.org> wrote:
>> On Fri, Feb 27, 2009 at 8:10 PM, Ibrahim Mohammed
>> > Hi,
>> > I am a new grass user and just wondering has anyone managed to get GRASS
>> > 6.4RC 3-2 running on a XP 64 bit machine.
>> > I tried to install it and I got python.exe error (unable to find
>> > libexpat.dll).
>> Please check if libexpat was installed (I assume that you use the
>> osgeo4w installer).
>> Markus
> IBRAHIM N. MOHAMMED
> Utah State University
> Research Assistant
> Civil & Environmental Engineering
> Utah Water Research Laboratory
> Logan,  UT. 84322-4110
> Tel: (435) 797-3533
> Email: Ibrahim.mohammed at aggiemail.usu.edu
> grass-windows mailing list
> grass-windows at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-windows
More information about the grass-windows mailing list
