[GRASS-windows] compiler error 'undefined reference to G_gisinit(char const*)
Markus Neteler neteler at osgeo.org
Fri Mar 6 14:48:18 EST 2009
On Fri, Mar 6, 2009 at 1:39 PM, KB <kartik.ballal at wipro.com> wrote:
> Hi,
> I have installed 6.2.3 version on windows and trying to compile r.example
> using cygwin. I am using below command from /usr/local/grass-6.2.3 path
> gcc -I ./include main.cpp
> on executing the above command I get an error 'undefined reference to ...'
> (all function used in rater.c). Please help ...
You need to add the path to the GRASS include files.
Markus
More information about the grass-windows mailing list
