Re: [GRASS-windows] Cygwin doesn´t starts
Colin Nielsen colin.nielsen at gmail.com
Wed Mar 18 11:42:24 EDT 2009
Try starting a command prompt (Run->cmd.exe) change to the directory
where cygwin_grass.bat is, and then run cygwin_grass.bat. This way the
window will stay open and you can read the error message. Email back
with the error and we'll try to help.
-Colin
On Tue, Mar 17, 2009 at 3:17 PM, epost_jj <epost.jj at gmail.com> wrote:
> Did you have a solution to this?
> I get the same problem....
> It opens and close within second.
> Baptiste Laville wrote:
>> Dear Wingrass users,
>> May somebody helps me to resolve my problems with Cygwin.
>> I am working with windows XP. To be able to use r.in.aster (I must import
>> an .hdf file) I can´t work no more with the native Wingrass installation.
>> So I try to install the Wingrass with Cygwin.
>> I followed the instructions of the internet page
>> http://grass.itc.it/grass63/binary/mswindows/cygwin/:
>> For installation of Cygwin, see
>> http://geni.ath.cx/grass.html#_Cygwin_setup_package. The instructions
>> given there can be used with slight modification.
>> Due to a recent change within the Cygwin installer program you must now
>> start Cygwin's setup.exe from the command line as "setup.exe -X".
>> At step #3 use http://grass.ibiblio.org/grass63/binary/mswindows/cygwin/
>> (or a local mirror) instead of http://geni.ath.cx/grass.
>> In step #5 the version is 6.3.0-2 instead of 6.0.cvs-1, and there's no
>> grass.bat script.
>> I downloaded the Cygwin program successfully.
>> But when I try to start it, it just pop up and desappears after less then
>> 0.1 sec.
>> I tryed all my best and spend long long time dealing with it ...
>> But now I need your help...
>> Thanks really for your answers
>> With my best regards
>> Baptiste
>> _________________________________________________________________
>> News, entertainment and everything you care about at Live.com. Get it now!
>> http://www.live.com/getstarted.aspx
>> grass-windows mailing list
>> grass-windows at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-windows
> View this message in context: http://n2.nabble.com/Cygwin-doesn%C2%B4t-starts-tp2170252p2493287.html
> Sent from the Grass - Win mailing list archive at Nabble.com.
More information about the grass-windows mailing list
