Re: [GRASS-windows] Cygwin doesn´t starts
epost_jj epost.jj at gmail.com
Wed Mar 18 12:17:24 EDT 2009
Got into Cygwin ok.
Fired up grass62 ok.
Downloaded spearfish dataset and tried to get in...
Here's the message that I have:
GRASS homepage:                          http://grass.itc.it/
This version running thru:               GNU Bash (Cygwin)
(/usr/bin/bash.exe)
Help is available with the command:      g.manual -i
See the licence terms with:              g.version -c
If required, restart the graphical user interface with: gis.m &
When ready to quit enter:                exit
GRASS 6.2.3 (spearfish60):/grassdata > child process exited abnormally
Error in startup script: can't read "monitor_zooms(1,1,n)": no such variable
    while executing
"lappend region $monitor_zooms($mon,1,$attr)"
    (procedure "MapCanvas::currentzoom" line 13)
    invoked from within
"MapCanvas::currentzoom $mon"
    (procedure "MapCanvas::coordconv" line 23)
    invoked from within
"MapCanvas::coordconv $mon"
    (procedure "MapCanvas::create" line 68)
    invoked from within
"MapCanvas::create"
    (procedure "Gm::startmon" line 11)
    invoked from within
"Gm::startmon"
    (procedure "Gm::create" line 69)
    invoked from within
"Gm::create"
    (procedure "main" line 30)
    invoked from within
"main $argc $argv"
    (file "/usr/local/grass-6.2.3/etc/gm/gm.tcl" line 521)
Thanks!
Colin Nielsen wrote:
> Hi,
> Try starting a command prompt (Run->cmd.exe) change to the directory
> where cygwin_grass.bat is, and then run cygwin_grass.bat. This way the
> window will stay open and you can read the error message. Email back
> with the error and we'll try to help.
> -Colin
> On Tue, Mar 17, 2009 at 3:17 PM, epost_jj <epost.jj at gmail.com> wrote:
>> Did you have a solution to this?
>> I get the same problem....
>> It opens and close within second.
>> Baptiste Laville wrote:
>>> Dear Wingrass users,
>>> May somebody helps me to resolve my problems with Cygwin.
>>> I am working with windows XP. To be able to use r.in.aster (I must
>>> import
>>> an .hdf file) I can´t work no more with the native Wingrass
>>> installation.
>>> So I try to install the Wingrass with Cygwin.
>>> I followed the instructions of the internet page
>>> http://grass.itc.it/grass63/binary/mswindows/cygwin/:
>>> For installation of Cygwin, see
>>> http://geni.ath.cx/grass.html#_Cygwin_setup_package. The instructions
>>> given there can be used with slight modification.
>>> Due to a recent change within the Cygwin installer program you must now
>>> start Cygwin's setup.exe from the command line as "setup.exe -X".
>>> At step #3 use http://grass.ibiblio.org/grass63/binary/mswindows/cygwin/
>>> (or a local mirror) instead of http://geni.ath.cx/grass.
>>> In step #5 the version is 6.3.0-2 instead of 6.0.cvs-1, and there's no
>>> grass.bat script.
>>> I downloaded the Cygwin program successfully.
>>> But when I try to start it, it just pop up and desappears after less
>>> then
>>> 0.1 sec.
>>> I tryed all my best and spend long long time dealing with it ...
>>> But now I need your help...
>>> Thanks really for your answers
>>> With my best regards
>>> Baptiste
>>> _________________________________________________________________
>>> News, entertainment and everything you care about at Live.com. Get it
>>> now!
>>> http://www.live.com/getstarted.aspx
>>> grass-windows mailing list
>>> grass-windows at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-windows
>> View this message in context:
>> http://n2.nabble.com/Cygwin-doesn%C2%B4t-starts-tp2170252p2493287.html
>> Sent from the Grass - Win mailing list archive at Nabble.com.
View this message in context: http://n2.nabble.com/Cygwin-doesn%C2%B4t-starts-tp2170252p2498058.html
More information about the grass-windows mailing list
