Re: [GRASS-windows] Cygwin doesn´t starts
epost_jj epost.jj at gmail.com
Thu Mar 19 11:17:58 EDT 2009
Re-installed the missing packages and everything works fine now.
Thanks a lot, Colin and Markus.
Markus Neteler wrote:
> On Wed, Mar 18, 2009 at 5:17 PM, epost_jj <epost.jj at gmail.com> wrote:
>> Got into Cygwin ok.
>> Fired up grass62 ok.
>> Downloaded spearfish dataset and tried to get in...
>> Here's the message that I have:
>> GRASS homepage:                          http://grass.itc.it/
>> This version running thru:               GNU Bash (Cygwin)
>> (/usr/bin/bash.exe)
>> Help is available with the command:      g.manual -i
>> See the licence terms with:              g.version -c
>> If required, restart the graphical user interface with: gis.m &
>> When ready to quit enter:                exit
>> GRASS 6.2.3 (spearfish60):/grassdata > child process exited abnormally
>> Error in startup script: can't read "monitor_zooms(1,1,n)": no such
>> variable
>>    while executing
> please check the mailing list archive for this - it's the classical
> GDAL-does-not-work eror.
> To see it, enter:
> g.region -p
> Markus
> grass-windows mailing list
> grass-windows at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-windows
View this message in context: http://n2.nabble.com/Cygwin-doesn%C2%B4t-starts-tp2170252p2503475.html
Sent from the Grass - Win mailing list archive at Nabble.com.
More information about the grass-windows mailing list
