[GRASS-dev] Re: [GRASS-windows] windows qgis-grass: make grass build with vc or keep a separate qgis-grass mingw build?
Thu Mar 26 14:44:32 EDT 2009
Jürgen E. Fischer wrote:
> FMPOV the build system is the real issue not the codebase.
The build system is a non-issue, as it doesn't affect the resulting
binaries.
Maintaining DSW/DSP files (or nmake files) isn't a realistic option,
and anything else will be "foreign" on Windows.
More information about the grass-windows mailing list
