[GRASS-windows] scripting on WindowsNative OSGeo4 Grass
Milton Cezar Ribeiro miltinho.astronauta at gmail.com
Fri Mar 27 16:41:19 EDT 2009
Hi Markus,
I fact I can open grass as text mode and copy and and past some command.
But when I tryed something like :
r.reclass input=A output=b <<EOF
1 = 1
2 = 5
3 = 5
EOF
I get error. So I am understanding that I can't use the capability of bash
when running grass under OSGeo4W_Shell (from where I started grass -text).
I also tryed to start grass from MSYS, but I got the following error
message:
Starting GRASS ...
WARNING: The wish command does not work as expected!
Please check your GRASS_WISH environment variable.
Use the -help option for details.
Switching to text based interface mode.
Hit RETURN to continue.
And AFTER Windows Vista say the libgrass_vask.6.4.0RC3.dll was not found.
May be a issue of Vista & OSGeo4W, or also my inexperience.
Best wishes
milton
2009/3/27 Markus Neteler <neteler at osgeo.org>
> On Fri, Mar 27, 2009 at 4:32 AM, Milton Cezar Ribeiro
> <miltinho.astronauta at gmail.com> wrote:
> > Dear all,
> > On native wingrass 6.3 runing under Msys (on a XP machine)
> > I could run scripts that I put under c:\grass\scripts.
> In theory it should be still the same.
> > But now I installed native wingrass under Vista from OSGeo4.
> > If I am not wrong now I don't need Msys.
> AFAIK it is always installed.
> > But how can I run my scripts that I put under
> > C:\OSGeo4W\apps\grass\grass-6.4.0RC3\scripts ?
> Aren't they accessible if you use the command line? See
> http://trac.osgeo.org/osgeo4w/wiki/pkg-grass#Usage
> Markus
URL: http://lists.osgeo.org/pipermail/grass-windows/attachments/20090327/3087a1c8/attachment.html
More information about the grass-windows mailing list
