[GRASS-windows] r.stats | awk | reclass under WinGrass OSGeo4W
Milton Cezar Ribeiro miltinho.astronauta at gmail.com
Sat Mar 28 16:56:49 EDT 2009
Hi Markus,
The following worked fine to me under Vista (64bits) on a DELL machine:
GRASS_WISH=/c/OSGeo4W/bin/wish.exe
export GRASS_WISH
after that I gone to /c/OSGeo4W/apps/grass/bin and typed grass64
 Thanks a lot.
Milton
Toronto, CA
2009/3/28 Markus Neteler <neteler at osgeo.org>
> On Sat, Mar 28, 2009 at 6:23 PM, Milton Cezar Ribeiro
> <miltinho.astronauta at gmail.com> wrote:
> > I tryed to start WinGrass from MSYS(MINGW - C:\OSGeo4W\apps\msys)
> > but when I type grass64 I got the following error message:
> > Starting GRASS ...
> > WARNING: The wish command does not work as expected!
> > Please check your GRASS_WISH environment variable.
> > Use the -help option for details.
> > Switching to text based interface mode.
> > Hit RETURN to continue.
> Before starting, please try to set
> GRASS_WISH=/osgeo4w/apps/tcl-tk/bin/wish.exe
> (maybe the syntax is different, could be
> set GRASS_WISH=%OSGEO4W_ROOT%\apps\tcl-tk\bin\wish.exe
> Also with could be wish80.exe or so (just guessing, have no Windows here).
> After setting, try to start GRASS.
> Please report...
> Markus
URL: http://lists.osgeo.org/pipermail/grass-windows/attachments/20090328/0ef14ba6/attachment.html
More information about the grass-windows mailing list
