[GRASS-windows] CompileOnWindows finished
Milton Cezar Ribeiro miltinho.astronauta at gmail.com
Sat Mar 28 22:20:37 EDT 2009
Hi Colin & coleagues,
I started since the begining, following all the steps the Colin provided,
and
almost on my machine (a Vista with 64bits) it appears to works fine.
To do so, I removed completely the C:/OSGeo4W dir. I must confess that
on the first time I included some extra libs, and it made I get some errors
during the compilation, and also after when I tryed to start GRASS.
By the way, I remember that almost on my case I needed to incluide
to extra steps before start GRASS
GRASS_WISH=/c/OSGeo4W/bin/wish.exe
export GRASS_WISH
cd /c/OSGeo4W/apps/grass/bin
grass6
Colin, addictionally I suggest you include the format of path as unix
on some steps, because it facilitate the copy and past (just to save
time of those the decide to handle the things on MSYS).
3. Copy c:\osgeo4w\apps\msys\etc\fstab.sample to
c:\osgeo4w\apps\msys\etc\fstab (without .sample)
    or
 cp /c/OSGeo4W\apps\msys\etc\fstab.sample /c/OSGeo4W\apps\msys\etc\fstab
4. Open c:\osgeo4w\apps\msys\etc\fstab
   or /c/OSGeo4W/apps/msys/etc/fstab
3. Open c:\osgeo4w\usr\src\grass64\mswindows\osgeo4w\package.sh and at line
12: Change:
or /c/OSGeo4W/usr\src/\grass64/mswindows/osgeo4w/package.sh
Finally, now I get grass65 and not grass64, so I suggest update this.
So, Colin and colleagues, THANKS a lot!!!
miltinho
2009/3/28 Milton Cezar Ribeiro <miltinho.astronauta at gmail.com>
> Hi Colin,
> Sorry, I really forgot the zlib-devel. My mistake.
> But now I compiled and I have other issue.
> When I start MSys, and define GRASS_WISH,
> and execute GRASS I get the box to select
> my MAPSET. After that I get the following error message:
> This application has failed to start
> because libintl3.dll was not found.
> Re-installing the application may fix this problem.
> Any idea? I need do compile GRASS again (how can I recompile?).
> Best wishes
> miltinho
>   Toronto, CA
> 2009/3/28 Colin Nielsen <colin.nielsen at gmail.com>
>> I believe you're missing the zlib-devel package, it contains zlib.h.
>> (Re-)install this package, then try again. If it still fails, verify
>> that zlib.h is in /osgeo4w/include. If it is there but is still
>> failing let us know.
>> -Colin
>> On Sat, Mar 28, 2009 at 4:47 PM, Milton Cezar Ribeiro
>> <miltinho.astronauta at gmail.com> wrote:
>> > Dear Colin,
>> > Thank you very much for your great work.
>> > I am trying to follow your steps on a 64bit Vista Machine,
>> > and got the following error.
>> > checking for socket... no
>> > checking for socket in -lsocket... no
>> > configure: warning: *** Unable to locate socket() function.
>> > checking for location of zlib includes...
>> > checking for zlib.h... no
>> > configure: error: *** Unable to locate zlib includes.
>> > Any idea?
>> > Best wishes,
>> > milton
>> > Toronto, CA
>> >> I just wanted to announce that the CompileOnWindows wiki entry
>> >> <http://trac.osgeo.org/grass/wiki/CompileOnWindows> is finished and
>> >> now allows anyone to develop grass on windows (vista or xp) through
>> >> the mingw/msys system with no dependency compiling and relatively
>> >> little extra work (thanks to jef for solving all remaining issues by
>> >> adding the mingw-libs package to the wiki).
>> >> -Colin
>> >> _______________________________________________
>> >> grass-windows mailing list
>> >> grass-windows at lists.osgeo.org
>> >> http://lists.osgeo.org/mailman/listinfo/grass-windows
URL: http://lists.osgeo.org/pipermail/grass-windows/attachments/20090328/0ac225e4/attachment.html
More information about the grass-windows mailing list
